Plans have you fit foam fairing blocks between the OD bulkhead and the wing root. I had considered making them now, but the bottom edge of both OD still needs trimming, and I would have to allow for the outer strake layups. I will later probably not be bothered re-fitting the wings just to profile this fairing block, butI am mindful that some transitions between wing and strake have offended my eyes in the past. Decide to hot glue a false rib to the forward face of the spar tip, which matches closely the wing root. When the wings are off I can make another, glued to the outer face of the spar tip to match it. I can then remove the first false rib, and the second will be a nice thing to form the outer fairing block to match. If I don't manage to knock it off...
