Home of the Spodplane
Date: 7-26-2020
Number of Hours: 4.40
Manual Reference: 21-06
Brief Description: OD bulkheads and fuel lines
Flox in the fuel feed lines from both blisters to the sump tank, and the feed from the sump tank. Clamp them with a rats nest of stick props, which fall down a lot. Secure line ends in place with multiple layers of 4oz cloth, all with EZpoxy. Tape the delivery line inside the sump tank with 2 x 4oz and extend the existing t-hats to the fuselage bottom with 2 x 4oz.
Secure the pipes between the ends with more 2 x 4oz tapes, with MGS epoxy. Taped the port line where it will go under the port rear seatback with 1 x BID, for a bit of extra resistance.
Taped between the starboard OD bulkhead, (smoke oil tank) and the spar/top strake skin with 1 x 4 oz, then 1 x BID over both OD bulkheads, lapping 1" onto centersection spar front face.
Leftover resin turned to dry micro and filled some strake top skin grooves.
Wetting out port OD skin
Stipply, stipply
Pipes all in, installing tapes
