Trimmed up previous work and find it good. Had worked at making an overlap, which didn't quite work, but also decided it didn't matter as I can just tape the joins when the top skin goes on.
Trialled a new way to store pre-cut tapes a while ago, cutting heaps and keeping them in a small plastic container. This is working well so spent ages cutting up 4oz into 2" tapes, and peel ply into 1" edge tapes, and put them all in plastic containers.
Spent some time contemplating fuel caps. I wondered if the supplied flance would require the inner skin to be dropped at all, but I believe not. I am contemplating preparing a site for the fuel caps before glassing the outer foam, but will need a way to get the glass to lay down in the depression.
