Enlarge the fuselage holes a bit to facilitate taping, then realise that I can use MGS here, so I'll do it later. I don't want to confuse myself, the MGS mixing table is covered up at the moment.
Trial assemble the remaining port strake bulkheads and discover the solid ribs make it a breeze, Rather than juggling levels and adjusting at every step they are locked in and can be used to positively locate the other with hot glue blocks and props. Brilliant.
Taping was a miserable experience last time but now I can do all the long ones in long lengths, and with better access. I just had to be careful not to disturb the tapes when floxing the bulkheads over the uncured tapes, which I now did.
