Home of the Spodplane
Date: 4-8-2020
Number of Hours: 3.60
Manual Reference: 21-02
Brief Description: Port strake, lower skin
Decide that something uplifting should be visible through the filler when gassing up the Spodplane, so make an attempt at a suitable life drawing on the foam.
Prep the foam, using a plans rubber squeegee for a change, but it just can't get the excess micro out, so back to a credit card. I am running out of credit cards. Then 1 x BID over inside skin of port strake, 537g of EZpoxy used. Really liking this roller caper, try to clean it with acetone afterwards. Maybe worked. I vaguely remember covering the starboard skin with one width of BID, but I can't find a join, and seem to have misplaced the pictures. The join may be under R57
New batch of hardener EZ87B lot 8144P73646
New batch of resin EZ10A lot 8304P75809
This means I've used half of the EZpoxy I bought for the strakes, and I'm probably over half way through.
Slather on some micro.
Rolling, rolling
Getting a bit low on peel ply
