Home of the Spodplane
Date:  4-6-2020
Number of Hours:  1.80
Manual Reference:  21-02/05
Brief Description:  Port strake assembly
Fiddled some more with the port strake bulkheads.
Mark the rib positions on the bottom skin and hot glue some locating blocks on the spar to locate the ribs. These blocks are a bit smaller than the last, about 1" long, and with the grain in line with the joint for easier removal. Decide on a different approach to last time. I'll flox on R57 & R/B33 and do the rest later.
Trimmed the 5 min join on the skin foam.
Marked, cut and sanded the fuel drain.
Dug out the pour foam I haven't used in ages and started to fill in the starboard strake void. Started with 30/30ml.
Goes here I think
Goes here I think
Noice!
Noice!
Trimmy, trimmy
Trimmy, trimmy
