Figger that the rudder cable will have to extend to 350mm from c/l to ensure connection to the fuselage cable, Do some measuring and figgering and decide this means the cable needs to extend 440mm inboard of the wing root.
Cut the right cable here and terminate and fit the left cable. It works OK, and has nice travel, but is binding somewhere in the last inch of travel. Can't see where.
Cable fitter
Travel is good, scratchy noise for last inch... :(
