Home of the Spodplane
Date:  1-10-2019
Number of Hours:  0.90
Manual Reference:  20-05/06
Brief Description:  Lower Winglet installation
Shaped the wingtip filler pieces a bit more. I had planned to skin them and the lower winglet before inverting the wing, but can't visualise what it will all look like, so left that for a bit and inverted the wings, (now the right way up). Knocked off all the hot glue blocks at the Wing/Winglet join, with difficulty. Basically had to break up the blocks with a wood chisel and then chisel off the glue. Perhaps the glue had been hardened by the exotherm?
Shaped the wingtip filler a bit more, relieving the wing skin a bit to achieve a shape that pleased me.
Stuck some bits of wing foam to allow the shaping of the internal wingtip for the bellhorn tip the same as the lower surface, just in case. Will be contained in the fillet.
Marked up for layup #4, as planned just marked the centerline, the length of each layer, and the outline of the first UND layer.
Roughly filled the Winglet join with really dry micro.
Shapey, shapey
Shapey, shapey
This job getting more and more awkward
Marking up the second Wing
