Home of the Spodplane
Date:  12-13-2018
Manual Reference:  20-03
Brief Description:  Upper Winglet installation prep
Layup all OK, wing repair best yet.
Played with CS Spar placement, Levelled the Fuselage and checked the levels. It is not quite right, and the spar is a very tight fit. Surprised me, after reading about others that had to shim the Spar up to the upper Longerons, or mount it too low, (Marc?). Hmmmmm.
After the inspection I had 30 min free so started trimming the Wing tip. I cut the top skin/spar cap/shear web with the multitool, then hogged up the foam with a hacksaw blade. Off to work!
Top skin cut, contemplating Spar cap
Hogging out foam
Hogging out foam
