Home of the Spodplane
Date:  10-20-2018
Number of Hours:  1.10
Manual Reference:  20-01
Brief Description:  Winglet core assembly
Glued up one lower winglet with Sikaflex Urethane Bond, to see how it cured in the supporting blocks. If it is all permanently re-assembled into a block I can start again. I can't start again with the upper winglet, if one of them fails I will have to get more foam.
Tried to assemble the supporting foam blocks for the upper winglets, which had fallen apart, but got a bit muddled.
Tried to fire up the hot wire saw to trim the tip blocks, no soup. Fiddled, pulled it apart. No soup.
Trying to put together the supporting blocks
Fingers crossed, glued up.
