Got myself 2 x 12x1200x400mm mdf sheets and marked up the 9.5x48" for the Winglet TE. Used the cutting templates to mark up the LE.
Made plywood jigs to hold the root and tip Winglet templates level reference each other and 0.1" from the workbench. They are inverted so they will sit flat for the outer surface skin. Stuck some feet on them and propped them either side of the mdf, and roused out the foam I had reserved for the 'remaining' winglet. However I tilted the foam and farted around with the templates I could not orient everything to achieve a usable core. F*&k!
Got despondent and drank a lot of wine. Am I going to have to buy more foam???
