Home of the Spodplane
Date:  7-1-2018
Number of Hours:  1.20
Manual Reference:  16-01
Brief Description:  Controls - Roll
Still too cold for fibreglassing, and too depressing to sand back the Left Wing ribs, so worked more on the controls.
Finished the mocking up of the hardware, and updated the other side to match, Rechecked all the numbers.
De-rigged all the metal, ready for the floxing of CS109/118.
Read a fortuitious tip in an old Sport Aviation that showed how to make a custom sized c-clamp out of plywood and bits lying around the shop. Made some giant c-clamps out of 19mm ply from a pallet, tightened with the wedges I made for the longeron clamps when building the sides. They work fine, so I can abandon the flox/5-min plan, and I may even use urethane glue.
Clamping, clamping
Clamping, clamping
