Home of the Spodplane
Date:  6-23-2018
Number of Hours:  6.00
Manual Reference:  19-08
Brief Description:  Left Wing top skin layup
Prep sanded glass areas with 80g & prepped foam.
Stapled peel ply strip on leading edge of aileron. As usual had to strip down the stapler twice before the end...
Upper skin layup as per plans. Micro'd foam and floxed gaps between spar cap and shear web, ends of plies in the spar cap and trailing edge overlap are where foam was removed by the peel ply, 2 x UND crossways. 1 x UND along the wing forward of the aileron. 2 bits of UND reinforcement at the notch, and 1 x BID over the tip. All joins peel plied. 2.7kg of resin used, Made one batch of 350g when the lid fell off a resin bottle. Thankfully was able to calculate the required extra hardener before the scales reset.
Prep da foam
Prep da foam
Micro da foam
Micro da foam
2nd ply of UND
2nd ply of UND
