Home of the Spodplane
Date:  5-29-2018
Number of Hours:  1.90
Manual Reference:  19-10
Brief Description:  Right Aileron hinges
Bonded in right Aileron clickbonds with wet flox, hinges held down with well greased hardware nuts at FT tension.
Faired in clickbond heads with flox, 1 x BID over the heads, overlapping heads by 1"
Played some more with CS127 and other Aileron hardware. Mounted all, mostly with un-torqued aviation hardware to check fit. Will have to remove it all to fit the Aileron torque tube, once I discover if the Aileron can actually be removed...
Hold clickbond head with finger, fit and tighten the nut, repeat.
Trying out the hardware again
