Home of the Spodplane
Date:  5-28-2018
Number of Hours:  1.30
Manual Reference:  19-10
Brief Description:  Right Aileron hinges
Tried again with the clickbonds, and discovered I could ooger out the wing holes with the reamer, without affecting or enlarging the holes in the hinges. Proceeded to do so, fitting clickbonds with hardware nuts as I go.
Adjusted cleco recesses with Dremel router so all threads are square.
Removed all, ground a tiny "D" in the perimeter of the clickbonds, sanded the heads with 180g and soaked them all in metho.
Taped up hinge faces, fitted Aileron with 2 cleco's in each hinge piece. Cut some BID go go over clickbond heads and prep sanded area.
Oogering out the Aileron mounts
Recessing skin for clickbonds
Cutting up some BID for the clickbond heads
