Home of the Spodplane
COZY MK IV
Right Aileron hinges
Removed Aileron, drilled reamed and hardware rivetted mid hinge to Aileron. Just in case, marked all non-aviation rivets with a black marker.
Replace Aileron. It is aligned properly and moves beautifully!
Played for a time with the leading edge Aileron gap on the lower surface, using 1/2" sanding drum and 6mm sanding board. In progress.
Checking hinge action
Opening up the gap
COZY MK IV Home
3465
Casa del Spodd
CH03 - Repair
CH04 - Fus Bulkheads
CH05 - Fus sides
CH06 - Fus Assembly
CH07 - Fus Exterior
CH08 - Fus Innards
CH09 - MLG
96
217
CH10 - Canard
CH11 - Elevators
CH12 - Fit Canard
CH13 - Nose
141
256
CH14 - Center Spar
53
117
CH15 - Firewall
CH16 - Controls
CH17 - Air Brake
CH18 - Canopy
125
325
CH19 - Wings
176
407
CH20 - Winglets
94
179
CH21 - Strakes
144
369
CH22 - Electrical
CH23 - Engine & Cowl
87
241
CH24 - Seats, Armres
132
228
CH25 - Finishing
145
469
Materials
TC reports
