Home of the Spodplane
Date:  3-14-2018
Number of Hours:  6.20
Manual Reference:  19-08
Brief Description:  Right Wing top Spar Cap
Trimmed layup, all good.
Sanded/routed edges and removed dams.
Finish sanded foam. Note for the first time that the LE is not terribly straight. Bit of a hump in the middle, and a hollow beneath. Further investigation required.
Cut the trough for the Rudder cable conduit using Dremel router attachment against a bit of timber
Marked up plies for top skin, cut reinforcement bits and peel ply.
Can't do layup yet, waiting for a new batch of resin and nyloflow tube for the rudder conduit.
Cleaning up bits of duct tape
Profiling the edges of the Spar Cap and resin blobs
Profing the edge of the bottom skin
