Home of the Spodplane
Date:  3-7-2018
Number of Hours:  5.90
Manual Reference:  19-06
Brief Description:  Right Wing lower skin layup
Applied a micro slurry then patched remaining divots with dry micro.
Filled flox corners around Wing Attach pockets and filled gaps between spar cap and shear web in the wing root.
Apply first skin ply, then notice the aileron peel ply is not in place. Peel it off, staple on peel ply and try again. 2 x UND over all. 2 areas of UND reinforcement near the notch, and 1 x BID over the tip. Peel ply all these, all joins and 2" of leading edge
Clamped straight edges to trailing edge, with 3mm pvc angle underneath.
Micro, micro
Micro, micro
Peel back the first layer to install the aileron peel ply. Idiot.
Stippling second ply
