Home of the Spodplane
Date:  2-28-2018
Manual Reference:  19-05
Brief Description:  Right Wing, Spar Cap prep
Re rigged Right Wing bottom side up on table with hot glue and glue blocks.
Removed lower jigs and smoothed corners of upper jigs.
Cut RFC4 square for wing rib
Started smoothing joints.
Aligning the jigs
Aligning the jigs
Grinding the joints
Grinding the joints
Cutting LE notch square
