Made a bigger heat tent frame, old one didn't fit over the assembled wing.
Dammed forward edge of LFC-1 with taped plywood, fitted with hot glue
Taped beside spar cap and marked on it required plies. Converted the rather cryptic table for ply length so I could measure from the root for the inbound cut, and from the tip for the outboard. i.e. from the 4th ply they finish 1 26 47 65 81 and 98" from the tip.
Back filled edges of spar cap with dry micro, and filled some foam divots with excess.
