Re-fitted W18 with flox. First hot-glued some taped mixing sticks to the outside surface, then mounted them with a clamp. Used a new electronic scale for epoxy mixing, accurate to .01g, making it safer to mix a really small batch, (14g) of epoxy. Thanks Santa!
Tripped over one of the jigs, will have to stick it down again. The bondo pulled up concrete!
