Home of the Spodplane
Date:  12-25-2017
Manual Reference:  19-04
Brief Description:  Right Wing Shear Web
Profiled Shear Web faces and recessed joins.
Re-fitted W18 with flox. First hot-glued some taped mixing sticks to the outside surface, then mounted them with a clamp. Used a new electronic scale for epoxy mixing, accurate to .01g, making it safer to mix a really small batch, (14g) of epoxy. Thanks Santa!
Tripped over one of the jigs, will have to stick it down again. The bondo pulled up concrete!
Checking block joins for high spots
W18, take #2
W18, take #2
Copyright © 2001-2018 Matronics. All Rights Reserved.
