Trimmed attach bolt cutouts so centerlines are parallel.
Made some calipers and a jig to drill a hole from the LE of the upper attach bolt hole to a point clear of the spar cap in the bottom one. This is for a drain, lined with 1/4" nylon tubing fitted with 5min flox.
Had pondered for a while that my TC had advised he would like to inspect again before the nose sections are glued onto the Shear Web. Figure I can have him for both if the Right Wing can be stored after the Shear Web layup. Made up a set of duplicate upper rear wing jigs, so the Right Wing can be stored on the one it is 5min floxed to.
