Home of the Spodplane
Date:  11-14-2017
Number of Hours:  1.00
Manual Reference:  14-07/09
Brief Description:  Wing CS Spar outer layups
Finished access holes. Actually cut out portion, taped the underside of a couple of penetrations of the BID, then covered with a bit of MDF hot glued from the inside. Inside of the spar looks cool, nowhere near as much micro drooling around as I was expecting.
Prepped foam and glass.
taping and re-sealing access holes
Sanding the overlap
Sanding the overlap
