Home of the Spodplane
Date:  11-11-2017
Number of Hours:  1.10
Manual Reference:  14-07
Brief Description:  Wing CS Spar outer layups
Trimmed layup, removing from the mounting. Almost lost the spar again breaking the bondo. Sucker is getting heavy.
Routed out the outline of the access holes and started hogging out the foam. Then note I have not yet installed the hardpoints, and I've just compromised my mounting point. Have a ponder, and decide to do it after the FWD out layup. Then reallise it will make the BID overlapping the UND over the LWA2/3 easier, as I can just wrap it around the ends, instead of a later flox corner. Maybe my subconsious was planning...
Decided my access holes were slightly too large, and the transitions too sharp, will fair it in a bit with flox, to minimise the glass-to-glass.
Spar is much more stable AFT face down.
Ripping off peel ply, my favorite bit!
Trimmy, trimmy
Trimmy, trimmy
Routing foam around access holes
