Home of the Spodplane
Date: 11-9-2017
Number of Hours: 2.40
Manual Reference: 14-07
Brief Description: Wing CS Spar outer layups
Finished trimming, and sanding. Have discovered the spar is unstable when sitting on the forward face, the weight of the spar caps makes it a bit tippy, and it got away from me once when I was rotating it. Caught it and kept it on the table thankfully. Pondered how to mount it, seeing I cant use bondo on the exposed foam, and I need to access the bevels which will present undercut for the next layup. Decided to mount a scrap 100 x 70mm board on the table, and screw a couple of bits of scrap chipboard to the forward foam, (through to the internal BID), in the bit that will be cut away for the access holes. Did so, and bondo'd the chipboard to the board. Looks OK. [Timewarp: Should have made the chipboard strips narrower, to make it easier to scissor trim the bottom edge.]
Marked up AFT, top and bottom surfaces at 45 degrees again
Spent a bit of time re-designing my fg roll dispenser to get it closer to the work.
Screwing mounting boards to the access hole cutout location
Mounting with bondo
Marking up at 45 degrees
