Home of the Spodplane
Date:  9-10-2017
Number of Hours:  2.20
Manual Reference:  14-03/04
Brief Description:  Wing CS Spar
Trimmed CS4 with Mr. Buzzy, on new cutting table with dust collector in itl
Re-glassed 1 x BID in right tip of CS Spar internal, overlapping 1" onto previous. I laid the BID over the area, held at the top with nails in the CS2/3, and wet it out in place, and more thoroughly than last time. Worked brilliantly. Wish I had done it this way the first time.
Smoothed the electrical cutouts in the internal bulkheads with 1/2" sanding drum in the dremel.
Fixed CS4 on left tip and central with sloppy micro. I fear it will drip down on the inside. Weighted for cure.
Trimmy, trimmy. Vacuum cleaner gets the dust.
Second bash at the BID
MOST of the CS4 fitted.
