Home of the Spodplane
Date:  8-25-2017
Number of Hours:  0.80
Manual Reference:  14-02/04/07
Brief Description:  Wing CS Spar
Mounted CS spar cap templates on 3mm ply and rough cut on electric coping saw. A lot easier than 10mm MDF.
Pulled nails from foam, removed a couple of blobs on the joins with dremel.
Cut out and sanded shoulder harness blocks from 1" Hoop pine.
