Home of the Spodplane
Date:  4-6-2016
Number of Hours:  0.70
Manual Reference:  16-01
Brief Description:  Fuselage bearing supports
Have sourced IGUS flange bearings, and getting my head around actually using them. Also considering that this needs to be the next chapter attempted. Everything going slow at the moment, as I wait for more materials, (some not ordered yet), and planning the new shed.
Cut out CS-109 x 2 & CS-118 x 2 from 1/4" Hoop pine marine ply.
Cut 35mm hole with fly cutter. Drilled and reamed 3/16" mounting holes for bearings.
Experimented with bushes to mount bearings with 3/16" bolts.
Trial fitting bearings
Copyright © 2001-2018 Matronics. All Rights Reserved.
