Home of the Spodplane
Date:  4-2-2016
Number of Hours:  0.80
Manual Reference:  13-05
Brief Description:  Nose and static point
Applied flox fillet to inside of nose bowl join to fus with a broken hacksaw blade, and filled gaps on the outside.
Attempted 2 x 2+2 tapes, but found it almost impossible to get into the acute angle. Ended up taping about 50% of the join on the inside, and all the way on the outside.
Didn't layup flange over Ballast Hatch, will use BID, after fitting the nutplates I don't have yet.
Micro'd in the static source pipe, injecting the runny micro with a syringe.
Applying flox fillet. Feeling a bit like a Gynecologist...
Static source pipe in
Copyright © 2001-2018 Matronics. All Rights Reserved.
