Cut exterior glass and routed foam for Ballast Hatch window.
Fitted hatch rubber seal and check fit. It all looks a bit tight. Not sure this is going to work. Nose bowl has cured with a bit of a warp, and doesn't fit cleanly on the nose either. Hmmmmm. Will evaluate. Beginning to think this pre-fab nose bowl is a bit of a WOFTAM.
Routing exterior foam for Ballast Hatch window
Fitted the rubber hatch seal. Oh Bog! It is warped!!!
