Home of the Spodplane
Cozy IV
Nose upper skin
Finished profiling door channels, including flox corner, as otherwise would only be 1/4" glass to glass.
Cut flox corner in LE, and profiled rest of foam for a smooth transition and maximum foot clearance.
Bit of an uneven gap over F-5, sanded the foam flat and cut a packing piece from scrap IP foam.
Adjusted foam to fit brake reservoir, (only one) on TE of F-5.
Fitted Nose Door K1000-3 nutplates in LE corners of nose
Sanding the flange
Profiling the foam
Fitting nutplates
Cozy IV Home
2210
Casa del Spodd
CH04 - Fus Bulkheads
CH05 - Fus sides
CH06 - Fus Assembly
CH07 - Fus Exterior
CH08 - Fus Innards
CH09 - MLG
74
179
CH10 - Canard
CH11 - Elevators
CH12 - Fit Canard
CH13 - Nose
122
212
CH14 - Center Spar
53
117
CH15 - Firewall
CH16 - Controls
CH17 - Air Brake
CH18 - Canopy
CH19 - Wings
166
392
CH20 - Winglets
88
169
CH21 - Strakes
132
349
CH23 - Engine & Cowl
CH24 - Seats, Armres
Materials
TC reports
