Home of the Spodplane
Date:  12-31-2015
Number of Hours:  2.80
Manual Reference:  13-08
Brief Description:  Nose gear doors
Had difficulty managing the backing boards with the nose gear foot, so adjust the boards.
Note nose strut cover is a bit proud aft, and sand back the SC tapes a bit to adjust.
With the stut cover flush am surprised to discover the nose wheel interferes with the doors. Pop them off the boards and make a bump from 1/4" H100.
Tape together the doors, with a multi-tool blade gap, and tape the gap with 1/4" masking tap. Install bump with micro and cover with 2 x BID with 1" overlap and peel ply.
Cut remainder of hinges from MS20001-6. 2 x 3", 2 x 2".
Trial fit of doors, wheel is in the way.
Micro the bump
Micro the bump
Peel ply
Peel ply
