Home of the Spodplane
Date:  11-5-2015
Number of Hours:  0.90
Manual Reference:  Step 5/6/7/8
Brief Description:  Fitting Nose Gear
Finished and prepped Al for rudder pedal outboard mounts.
Removed peel ply and inspected last layup, looks good.
Fitted nose wheel and MKNG-6 pivot bolt to Nose strut, used overhead light to trace outline of Nose Gear for cutting the hole in the Fus bottom. Seems like a dumb way to do it, reckon it will be easier to fit the gear and trace around it directly onto the fuselage with a set square, but probably best to have the template ready if I need it.
Rudder Pedal outboard mounts
Nose Gear outline template
