Home of the Spodplane
Date:  9-17-2015
Number of Hours:  0.50
Manual Reference:  Step 3
Brief Description:  Fixing Canard rear attach pins
In a bit of a rush, but figured I had time to flox in the pins.
Trimmed layup.
Drilled rear pin holes out to 1/4" and floxed them in.
Attempted to fit Canard, and discover the way I had relieved the sides for the Elevator torque tubes meant I could not slide the canard onto the pins. Also note the STBD side pin goes too far into its hole, because I had made it too deep. If I hadn't been in a hurry I would have made a trial fitting first. Stupid, stupid.
Removed all, cleaned out the flox and cleaned up the pins. Off to Orchestra practice in a grump. Ate too much for tea.
Trimming, trimming
Trimming, trimming
Pins floxed in and covered with box tape
Doesn't smegging fit!
