Home of the Spodplane
Date: 9-13-2015
Number of Hours: 2.90
Manual Reference: Step 2
Brief Description: Fitting Canard rear tabs
Trimmed pads and drilled F-22 to match tabs. Temporarily fitted Canard with AN3-12 bolts, 2 wide area washers and 4 AN960-10.
Cut the rear tabs from 1/4" hoop pine ply. Had to adjust the outer corners to match the curve of the Fuselage sides. Inserted the pins, sat a wide area washer 1/16" thick over each pin then placed on the rear tabs, fixing with 5-min epoxy with some flox mixed in. As the epoxy is going off realise it will be a bitch to profile, so mash in a couple of round biros to get the profile right-ish now.
After cure remove the pins, and clean up the 5-min a bit, after getting the biros off with difficulty...
Layup 5 x BID over the rear tabs, and 1.5" onto Canard and peel ply.
Is nice and warm in the shed on completion, but a cold night is forecast so set up the heater. Seemed a bit of a waste of energy seeing it was still 20 degrees, but didn't want to trust my memory to remember to turn it on later. Have a brain wave and go get the leftover thermostat I have for the fibreglass cuboard I never built and set it up under the heat tent, and plug in the fan heater. IT can remember to turn the heater on!
Making the pads purty
Attaching the rear tabs
Tabs glassed
