Brief Description: Canard tips and elevator counterweight
Continued trimming Canard tips.
Finished PORT hinge pin as I did the STBD.
Hogged out the inboard edge of the tips outboard of the elevators for flox corners and sanded where the BID will overlap.
Bondo'd the L jigs for the CS-10 onto the elevator, 8" from the tip of my original length elevators. Shame about the joggle I put in the wrong place.
Trimmed the CS-10 and the foam spacers untill they fit into the jigs, and squooge them on with 5-min with flox mixed in. After trimming they came out as STBD - 269g, PORT - 271g.
Fixed the hinge tube I had removed, (which was actually the PORT, now I look at it), with the same mix.
