Home of the Spodplane
Date:  3-25-2015
Number of Hours:  1.50
Brief Description:  MLG Inner Cover trimming
Peel ply stuck to the melamine. Looks like the resin dissolved it. Layup looks a lot better than last time, but did cause a delam on one side. Will sand down to the foam and patch it when installing.
Trimmed the layup with the multitool. Cut the access holes with a table jigsaw, cleaned up with sanding drum in the drill press.
Still think the double sided layup will work, but needs plastic both sides.
Trimming, trimming
Trimming, trimming
Trimming, trimming
Trimming, trimming
