Home of the Spodplane
Date:  3-8-2015
Number of Hours:  0.50
Brief Description:  MLG Outer Cover flange
After consideration, remembering advice from Terry Schubert at the last Australian Canard Muster checked for a smooth transition in the NACA, and found the cover it proud at the rear. Knocked it off again, and bondo'd it on correctly. Fell off again.
Looked hard at the problem, and decide the tight fit is the problem, it will only sit in position with force applied. Later.
