Home of the Spodplane
Date:  2-9-2015
Number of Hours:  2.50
Brief Description:  MLG Outer Cover, LB install
Finished figuring internal foam on Landing Brake and trimming exterior layup. Ended up about 3/8" thick, bit less over the strut, at the edges of the NACA. All fits flush with clearance from the strut. Outer glass overlap about 1" minus a bit for a curvy transition.
Drilled, tapped and screwed LB hinge onto Fuselage Bottom.
Drilled and reamed Hinge, Actuator Brackets and Landing Brake.
Plans R10 screws too short for Actuator Bracket. R11 OK. Likewise on hinge, except R10 works over ply insert. Screws still need torquing up. Trial assembled then bracket removed again for floxing.
Just need to round the edges
Drilling through hinge and Landing Brake
Juggling clecos and screws and nuts
