Home of the Spodplane
Date:  1-21-2015
Number of Hours:  1.00
Brief Description:  MLG tabs & Landing brake Hinge
Removed Landing Brake and popped off shims. Cut glass for fus bottom, mostly from scraps.
Drilled MLG Attach Tab holes with plans jig.
Started trimming edges of tabs. Thought I had gouged the torsional layups, but after sanding discovered I had just got a slice of resin.
Popping off LB shims
Drill went through first time after drilling through jig from each side :)
Trimming Tabs
Trimming Tabs
