Home of the Spodplane
Date:  1-10-2015
Number of Hours:  2.30
Brief Description:  Brakeline conduit
Peel ply in strips was a STUPID idea, took ages to strip it off a bit at a time.
Plans tells you to unmount the strut to sand it all flat, but I don't see the point. Sanded rear half with random orbit sander and 36grit, and will sand back the rest after the conduit BID is applied, meaning I only invert the strut once.
Hot glued on the coreflute to support the conduit, then 5-min on the 12mm flexible conduit.
Cut peel ply for conduit BID.
Cut Landing Brake hinge at 12", sanded and scotch brited.
Sanding LB hinge, conduit guide mounted.
Conduit mounted
Conduit mounted
