Brief Description: Outer seat belt mounts / Rear heat duct
Floxed in seat belt angles and screws. Torqued down from the inside, Viki holding the heads with a screwdriver.
Trimmed inner layup and assembled rear heat duct.
Carved transition piece and covered in box tape. Sanded it square on a sanding board, then pressed on some 40mm PVC water pipe, and sanded in a transition, then eased the round down to 1 7/16". For easy handling spiked it onto two nails driven through a block of wood.
Torquing up the mounting screws. I need a new torque wrench...
