Home of the Spodplane
Date:  6-9-2014
Number of Hours:  3.50
Brief Description:  Cut bottom spacers
Cut spacers from 3/4" foam using technique in previous TimeWarp. Due to wastage when doing the sides I'm a bit short of foam and have to make some parts out of bits.
[Timewarp 16/10/2015: Strangely, when the nose floor is put on in Chapter 13 you add a filler piece to fair the AFT face of F-22 to the floor. It would make more sense to build up leading edge of the floor until it is level with the top of F-22 before glassing and save some faffing about. It would also be easier to tape on.]
Cutting spacers
Cutting spacers
