Brief Description: Instrument Panel - stiffeners. MLG - hard points
Layup extra hardpoint for main landing gear bulkheads.
Trim original hardpoints.
5 minute stiffeners to IP. Layup tapes over foam and forms. Plans method of applying tapes sucks, they always distort when taken off the plastic. [Time warp 13MAY13: Have discovered tapes work better when 1. tape pattern over bench or cutting sheet. 2. tape clear builders plastic over pattern. 3. Cut peel ply to fit target spot and place over plastic. 4. Wet out glass over peel ply. 5. If tape needs to be trimmed 'pizza cutter' will cut wetted glass but NOT the peel ply. 6. Transfer result to where it should be. Peel ply can easily be removed for joints/whatever.]
