Brief Description: Instrument Panel - Front fail and redo
Finish trimming IP. WHEN FINISHED note layup is pathetically lean, lots of air between and under the layers. Assume it was too much heat applied, with air re-entering as it cooled. Stripped off with the heat gun on high and a paint scraper.
Part was a bit warped, but would flex flat. Layed up front again with lots of micro in the dings. Tried a 2" brush. Was a bit awkward and left black hairs which looked a bit gruesome. Don't mind the beige ones, I can pretend they aren't there.
