Daves Sonex Web Site
Date:  12-9-2010
Number of Hours:  1.25
Manual Reference:  W14
Brief Description:  Start the riveting of the ribs to the main spar.
Riveted Ribs 1,2 to the main Spar. On rib 2 the mandrel of rivet CCP 46 broke off 3/16 above the rivet. The forward rib flange was not completely seated so I used the dremel to grind away the mandrel so I could drill out the rivet. Next I will finish riveting the ribs and the rear spar.
This rivet needed to be removed.
