First atempt at an engine start. Engine ran for about 5 seconds. The rpm was to high and when I pulled it back it died. back into the shop. I removed, cleaned, adjusted and re-installed the carb. I also re-routed the fuel line a littler and installed 2 heat shields on the exhaust pipe.
Tied to John Deere
the entire minus the 6 nuts and bolts that hold it together.
