Brief Description: Fasten fuel tank straps. Install fuel fitting betw
Feeling a little overconfident that I could, and somewhat guilty that I did not attempt to climb into the forward fuselage head first, So I gave it a try. First I prepared a table along side of the fuselage to get in and a rope from the ceiling to pull myself out. I also had my cellphone handy just in case I got stuck. It was difficult but I was able to secure the fuel tank straps and connect the fuel line. The left rudder steering linkage nut is contacting the fuel line fitting. It appears that I can reverse the bolt to clear the fuel line. That will be on the-to do list for Josh.
Yes I was able to get in and install the fuel line and tank straps.
