Daves Sonex Web Site
Sonex Aerovee Tri-gear
L02
Cut fiberglass for nose-gear steering linkage.
Tonight I cut the fiberglass to make a boot for the nose-gear steering linkage . I traced the full size pattern from the plans to use as a pattern.
I also set the main gear leg supports into the fuselage just to check the fit. Looks real good.
Fiberglass and pattern for the Steering linkage boot.
Right gear leg support.
Sonex Aerovee Tri-gear Home
1483
Aft Fuselage
Aileron
Cowling
Cowling, wing tips,
Flaps
Fwd Fuselage
89
252
Horiz Stab and Eleva
Lights
Misc Hardware
Panel, Avionics, Wir
Polish
Turtledeck
Vert Stab and Rudder
Windscreen and Canop
Windscreen, Canopy,
283
